View FA statistics
Use this procedure to view FA statistics.
- Select Fabric Attach.
- In the content pane, select the Stats tab.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
Name |
Description |
PortIndex |
Specifies the port for which the FA statistics are displayed. |
DiscElemReceived |
Specifies the number of element discoveries received on the port. |
AsgnReceived |
Specifies the number of remote assignments received on the port. |
AsgnAccepted |
Specifies the number of remote assignments accepted on the port. |
AsgnRejected |
Specifies the number of remote assignments rejected on the port. |
AsgnExpired |
Specifies the number of remote assignments that have expired, on the port. |
AuthFailed |
Specifies the number of authentications that have failed on the port. |
DiscElemExpired |
Specifies the number of discovery elements that have expired on the port. |
DiscElemDeleted |
Specifies the number of discovery elements that are deleted on the port. |
AsgnDeleted |
Specifies the number of remote assignments deleted on the port. |
AsgnAuthFailed |
Specifies the number of remote assignment authentications that failed on the port. |
